メインコンテンツにスキップ
Galaxy S7 Edgeは Samsungの2016年最新モデルGalaxy S7のスクリーンがカーブしたデザインです。2016年2月に発表、同年3月11日に発売されました。モデル番号はSM-G935です。
Why phone overheats after repair?
i recently replaced the screen on my phone with a full replacement screen with frame and lcd assembly. The phone then worked fine for two hours and now it just says its overheating. no problems before the repair. but now phone is useless. any ideas???
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
Where did you get the screen from? Did you check if the new screen replacement has the thermal pads installed on it just like the original screen had?
Also you maybe should of asked Samsung before for pricing as they may be cheapest for screen replacements.
さんによる
Samsung won't fix it I called them first and yes it has the pads it was from a Samsung direct supplier
さんによる
Had a customer come through after sending it in to Samsung for repair. It came back broke again! And refused to refund him!
さんによる
コメントを追加
1 件の回答
ベストアンサー
Although painful, after you've just buttoned the phone, but you gotta. Check inside and see if anything is noticeably wrong or different. You may have damaged something during the repair
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
The heat comes from under one of the gaurds over the chips. I was very careful with the logic board. I made sure to use all precautions that i could.
さんによる
Could be the display is drawing too much power. You may want to exchange it for an different one. I've seen that happen before
さんによる
コメントを追加
回答を追加する
cellrepair さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 26
今までの合計 3,151
