メインコンテンツにスキップ
2015年12月にAppleが発売したiPhone 6s用のケース。Smart Battery Caseには、iPhone 6sの容量を高めるためにバッテリーが内蔵されています。
Do you sell the replacement battery for this case?
My battery on the iPhone was completely dead and basically relying on the case's battery, then I ordered new battery for iphone on ifixit and replaced it, now the case wont even charge and is basically dead, there a particualr battery for it that you sell? The replacement looks relatively easy/.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
2件の回答
ベストアンサー
Hopefully this is still under warranty and you can get it replaced by Apple.
The teardown states:
"Battery replacement is possible, but will likely destroy the microfiber liner.
The only possible repair—replacing the battery—is made difficult by very strong adhesive."
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
Yeah, I bought this case when it was released, needed the lightning connector that the mophie didnt have so I could use my carplay without removing phone each time. Purchase date was Jan 31st 2015 so I doubt its still under any warranty. Also, it only looks that I would mess up the interior felt lining which is hidden by the phone anyway, so it wouldnt really be a big eyesore, just getting the battery out from adhesive would be the most difficult.
さんによる
I use a high grade alcohol (methanol) and a syringe and shoot it under batteries to loosen the glue. Works well on MBP glued in batteries.
さんによる
this answer isn't helpful at all.. what is the type of battery and where can you buy it?
さんによる
This answer isn't helpful at all.. what is the type of battery and where can I buy it?
さんによる
コメントを追加
I’m in the same boat, i have an 18650 laptop cell soldered to the the board of the apple battery to test and the smart case works and charges………………………………….but i cant seem to find a similar capacity battery of the proper dimensions, i dont even need an apple battery, i have the apple batteries connector desoldered and ready to be used w any battery i just need one that matches the dimensions of the case
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Christian Postier さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 16
今までの合計 1,746
