メインコンテンツにスキップ
Asus ZenPad Z8 Model Number: P00J Released June 2016 Verizon exclusive. Asus ZenPad Z8 is powered by a 1.4GHz hexa-core Qualcomm Snapdragon 650 processor. It comes with 2GB of RAM.
Setting up email signature in ZenPadZ8
Can anyone help me get a signature set up in email (pop3 - not gmail) that is more than 1 line? The field for Edit Signature is a 1-line field and no return key. I've looked at keyboard settings, I've typed out all the info on the one line (it runs all together on a test email), and I have typed it out properly and cut and pasted into that field (same thing - all run together on one line). I have chatted with ASUS who lieterally told me they don't help set up email. I have the email downloading fine, I just need help configuring the table to accept a 5 line signature.
Help?? :-)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
usually you cannot modify it more than past that, there are 3rd party apps that you can use to get better signatures with more lines of information images etc. into your signature but natively the system wont allow for it.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Can you suggest a 3rd party app? This was a surprise for us as it's replacing a Samsung tablet that had no problem doing a 5-line business email signature. Thank so much for the help!
さんによる
you can use either of these they should work for you, depending on how elaborate your signature needs to be https://play.google.com/store/apps/detai... or https://play.google.com/store/apps/detai...
さんによる
Thank you so much!
さんによる
コメントを追加
How to Create Gmail Signature on iPhone and android
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
kathleen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 186
