メインコンテンツにスキップ
Released April 2013, model numbers GT-N5100 (3G & Wifi), GT-N5110 (Wifi), and GT-N5120 (3G, 4G/LTE & Wifi)
System UI has stopped
When trying to close apps on my note, I get the box that says, "Unfortunately, System UI has stopped>" How can I fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
I can not find anything of one u beta on my phone and I have not had update for December that you hope to find in January that this is a rip off or not this is something like getting windows ten on your computer
さんによる
コメントを追加
1 件の回答
最も参考になった回答
I had the same issue. Found several suggestions. I did press "volume up" and "home" while powering on which brought me to a maintenance menu. I chose the clear cache option. That did not seem to do anything. Next I went to the "Setup" and "Apps". I found the app named "Google App", cleared its cache and then removed updates (reverting to the original version). After that things seem to work okay.
I assume "Google App" will auto update again at some point and we'll see what happens then. In the meantime, I was happy to find a way to get things working without having to do a complete wipe of the system back to factory default.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
This was so easy. Thanks so much for the help.
さんによる
コメントを追加
回答を追加する
ltdeat さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 2,887
