Power pad not working
The buttons most work for timer but the start button stopped working can it be fixed
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Cause 1
Touchpad and Control Panel
To determine if the touchpad and control panel are defective, try pressing each of the buttons on the control panel. If some of the buttons respond correctly while others don’t, replace the touchpad and control panel.
Cause 2
Touchpad
To determine if the touchpad is defective, try pressing each of the buttons on the control panel. If some of the buttons respond correctly while others don’t, replace the touchpad.
Cause 3
User Control and Display Board
To determine if the control and display board is defective, try pressing each of the buttons on the control panel. If none of the buttons are responding correctly, replace the user control and display board.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 1,996
2 件のコメント
@rayleewhite what model is your microwave and what have you tried?
oldturkey03 さんによる
kenmore the button enter stopped working
haroldjpower さんによる
