メインコンテンツにスキップ
Samsung Galaxy AceはSamsung製のスマートフォンで、Adreno 200 GPU搭載の800MHzクアルコムMSM7227プロセッサを搭載しています。
31回答 すべてを表示
Getting Problem in hotspot in Samsung Galaxy ACE
Getting Problem in Samsung Galaxy ACE
I am getting problem in Samsung Galaxy ACE and the problem is in Hotspot. When I turn hotspot on and connects other devices, then my data network setting are automatically turned off and I lost data network. Then suddenly it goes on for few minutes and the again turn off. This is very annoying tubemate.
Please help me out of it, either in fixing this issue or I change the handset.
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi,
Try changing the following setting and see if it resolves the problem for you.
Not sure re your phone but go to Home > Settings > Wireless and Networks > WiFi Settings > WiFi (here is where I am not sure whether you have to tap the right hand soft key below the screen to get to the Advanced options box or if there is an icon for more WiFi settings) tap on Keep WiFi on During Sleep > and select always.
What may be happening is that when no data is being sent and the phone's sleep setting comes on (turns off screen to save power) the WiFi shuts down to save power as well and then when data is sent has to re-establish the connection before it can do so.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
HRWebSolution さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 112
