メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Wi-Fi版iPad Mini 2の修理ガイド。2013年10月22日発表、11月12日発売。iPad mini 2はiPad mini Retinaディスプレイモデルとして知られ、iPad Airのすべてのピクセルを7.9インチに小型化しました。
Accidentally replaced LCD digitizer without removing battery first
Hello,
I was wondering what I can do to power on my ipad mini 2 after I have replaced the LCD digitizer without removing the battery flex cable first? I read on the forum that you are supposed to put the battery cable on last after placing the LCD digitizer cable.
Also read that I may have to replace the fuse, which I'm not quite sure where it is located.
As of right now, the ipad is recognized on my laptop but, it doesn't power on.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント
If it is the backlight circuit needing troubleshooting the iPad should still display something but very dim.
Usually backlight filters / fuse / chokes (I think they are called) need to be checked for continuity via a digital multimeter.
さんによる
Also you can hold a flashlight over the display, and see if you can still see the display
さんによる
コメントを追加
1 件の回答
ベストアンサー
The backlight fuse is not a fuse but a ferrite bead. The purpose of the ferrite bead is to filter out high frequency noise on the line. When there is high frequency noise, the ferrite bead acts like a resistor and throttles the noise.
When a DC signal is applied, the bead behaves as a near short (usually only in the milliOhm range, depending on the bead).
This component typically fails when you forget to disconnect the battery before removing or replacing the LCD connector. To properly test it, you need to check it's resistance with a meter. For all intents and purposes, it should read as a dead short (~0 Ohms).
On the mini 2, it is L2200 and it is under the shield. If you have the right tools and experience, it is not a difficult repair. Otherwise, I suggest you find a micro-soldering repair shop to have it done professionally.
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
回答を追加する
chaubly さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 16
今までの合計 1,355
