Why is my tablet screen lights not bright anymore?
Hi I am Johan, my played games on my Samsung tab 4 531 10. inch and it over heat now the light are deem I cannot able to see a thing.
It did happen to me just go to settings >device>display>brightness> and change your level of u r device brightness ..... very important make sure also to take off automatic brightness
Hope it helps
このアンサーは役に立ちましたか?
have you checked the brightness on the phone? i have had this happen to me before and i thought the battery was dying so i did not use it. come to find out somehow i had adjusted the brightness and it was all the way down. lol. you may want to check this first often times its the simplest things that are the problem. I hope that this helps and you are gaming away soon.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 17
今までの合計 2,175
