メインコンテンツにスキップ
Smaller, thinner, quieter model of the Playstation 2 (SCPH-700xx) released by Sony in September, 2004.
89回答 すべてを表示
Replacing the optical drive of the PS2?
Hi, I have a PS2 that I bought second hand from a friend. Strangely, it works very well with my PSOne CDs, but when I put a PS2 DVD, it starts up, runs across the game opening and crashes. I've been told that is must be the optical drive - my friend must have used it as a DVD drive too - and would have to change. How do I do that?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
1 件の回答
ベストアンサー
Try cleaning your current one by getting either a cleaning disc that u put into the playstation or opening it up, most of the time the optical gets dirty or if you have an older playstation 2 then there is a gear the channels what media your system can play, if you search Google there are reviews on how to fix this problem. For parts you might check here http://www.mod-chip.com/ps2version.htm or here http://store.richspsxparts.com/pl2pa.htm... and if everything else fails go here www.ebay.com :) good luck.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Rodrigo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 9,982
