メインコンテンツにスキップ
第三世代の Surface Pro タブレットは、2014年6月20日にリリース。
Surface Pro 3 wont cut on after Screen replacement
Ive done a few surface pro 3 screens with no issue. This wont cut on at all after replacing the screen. Ive tried the original screen, a new power button, and a new charger.
The charger LED is white, which according to the Microsoft website indicates a charge.
Any help would be greatly appreciated.
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント:
Did you fix this issue? I'm having the same problem
さんによる
anyone sorted this?
さんによる
コメントを追加
2件の回答
Both the LCD and battery connectors have a tiny PC board that sits between the MB and the connector. When you disconnect the cable, there is nothing holding them in place and they often come loose and get lost. If the LCD one is missing, nothing shows on the screen. But it will turn on. You can check this by connecting a monitor via the HDMI cable. If the battery one is missing, it won’t charge and won’t turn on unless the power cable is plugged in.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I replaced the screen in one unit as well (completely destroying the old one in the progress like everyone does) and installed a new one. When I got the replacement screen it was delivered without the connecting cable to the motherboard (next to the connector for the digitizer and the battery) so I had to use the former one.
When I tried to power it up it would not show any signs of life so I connected an external monitor just to be sure and it worked like a charm. I found that the connection from the lcd to the motherboard was kind of wacky and wobbly so I used a small strip of duct tape under the metal strip which should do the job and it held perfectly.
By the way my unit would run easily without a battery connected!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
hustlemanentertainment さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 21
今までの合計 791
