メインコンテンツにスキップ
A large smartphone by LG, released in fall 2014. The LG G3 (D855) boasts a Quad HD IPS display and a 13-megapixel camera.
180回答 すべてを表示
Why won't cables fit my ports after phone was dropped in water?
I dropped my phone getting out of a vehicle last night, during a pretty heavy rainstorm. I looked for it for about an hour before I found it, facedown in a puddle. I carried it in, but bumped the screen, and it came on. (It was in a protective case, but not anything water-resistant, like an Otterbox.)
Everything worked, other than thinking that a device was plugged into the headphone port. Per an online search, I used a can of compressed air to blow out the port, and that icon went away.
Everything seemed fine, until I tried to plug my charger in. The cord would not fit. Same thing for the headphone jack. Any ideas on how to fix this? (Or clean it, in case mud is in there.)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You can try cleaning them out with isopropyl alcohol and a toothbrush, if that doesn't work then you probably need to replace the ports. The headphone jack is easy as it is modular so you can just pop it out and install a new one.
Follow this guide up to Step 9. LG G3 Screen Assembly Replacement
The charging port on the other hand is soldered onto the board so that would require soldering equipment and knowledge to desolder the old part and install a new one.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jamie さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 19
今までの合計 2,591
