メインコンテンツにスキップ
Released November 2006. Identified by product id: 200763U.
8回答 すべてを表示
Can I upgrade my IBM ThinkPad T60 to a 64-bit CPU?
I recently recieved an old ThinkPad T60 with a Core Duo T2400 CPU in it and 2GB or RAM. Is it possible to upgrade the CPU to a newer one, for example a Core 2 Duo, and would it be worth the time and money? Also, would it be possible to upgrade the RAM past 3GB if it had a 64-bit CPU or would that still not be possible?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Are you using Windows?
さんによる
コメントを追加
2件の回答
最も参考になった回答
Arie Copley-Radder, The links below gives a lot of good info on upgrading the Thinkpad T60. Good luck.
http://forum.thinkpads.com/viewtopic.php...
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Arie Copley-Radder "would it be worth the time and money" I do not think so. Remember that in order to actually notice a CPU upgrade you will have to run programs that are CPU extensive (large CAD/CAM drawings etc. come to mind) otherwise you may safe a few microseconds during everyday-tasks. I'd go with some more memory and maybe an SSD but would leave it at that.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
I normally would agree, but when I upgraded my Dell Inspiron 6400 from a Core T2300E (Just one model down from this guy's processor) to a Core 2 T7600, I was able to run 64-bit programs. Applications launched significantly faster, and web browsing also improved. I do some basic 3D modeling, but the motherboard-integrated graphics still couldn't handle it, and this guy likely has 945GM graphics chipset, just like most other laptops that use this series processors.
さんによる
コメントを追加
回答を追加する
Arie Copley-Radder さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 42
今までの合計 5,535
