Why bottom of my touchscreen is not working
I just replaced my lcd screen and now after the install 1cm part on bottom of the touchscreen is not working but lcd screen is just fine. so does someone know how to fix this?
no way to fix this one you just replace new lcd it will work...
このアンサーは役に立ちましたか?
but that doesn't make sense, if i just day ago replaced the screen.
hi before replace lcd did you check properly every point
just enter *#0*# all testing mobile option available you can test all in your mobile
i did chek again after the install that everything was in place. phone is restored so i cant get anywhere cause next button is in the are that isnt working...
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 789
