メインコンテンツにスキップ
A Sony camera in the HX series of the Cyber-shot line.
5回答 すべてを表示
scrolls through menus on its own uncontrollably
The camera scrolls through the menus ie. the flash menu and shooting mode menu the timer, single shot and multiple shot mode menu. It is also very slow processing images it has a fresh card.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
4件の回答
選択されたソリューション
Hello, i had the same problem. To solve this turn off the camera press hard on rotating button and rotate it around while still pressing hard on it. Do it several times. Should cure the problem. Good luck.
このアンサーは役に立ちましたか?
スコア 8
7 件のコメント:
I had the same problem too and this answer has fixed it. The camera shop where I bought it clearly didnt know this fix!
さんによる
Hello this help totally fixed my problem. Thank you so much indeed. I am so happy to have my camera working properly the same way as it was brand new! Thank you so much :)
さんによる
Awesome!!! It worked perfectly. Thanks so much :)
さんによる
HOLY COW! Thank you so much for this fix! I have had my Cybershot DSC HX50V for over 7 years and for 5 of those years it has been frustratingly uncontrollable.
I’m so excited to be able to use my camera again. I was always afraid when trying to delete an image that it would delete the wrong one or delete everything because the menu would flip randomly through all the options. ''
Thank you for saving me the cost of a repair that might not have even solved the problem!
From a (now) happy photographer in Florida
さんによる
wow - that easy
thanks a lot!
what is the mecanism behind the miracle?
さんによる
2件以上のコメントを表示
コメントを追加
Could those trick usable for sony a7ii? Mine has the sampe problem. Thanks.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Tried the press hard and twist about 20 times but it didn't work. I decided the pressing hard and turning the option button around must mean the contact below the dial was corroded. I sprayed all the buttons on the back and top with Contact Cleaner (WD40 contact cleaner) and twisted the dial back and forth while pressing down on it. No luck. Tried again, and YES!!!!! It worked! WhooHoo!!!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Sony a7ii didnt work. MORE HELP PLEASE
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mike Prucha さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 47
過去 30 日: 198
今までの合計 3,591
