メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Appleの2世代目のiPad AirでWi-Fiモデルのみを対象をしています。モデル番号はA1566です。
not responding screen black screen
hello,
i have bought new screen with the digitizer .. i had the iPad ready before the screen arrived it was working perfectly all i had to do is connect the cable for the new screen on the iPad and I'm done! what i didn't see coming is that the screen did not respond! its black i thought something must be not right with the screen so i plugged the old screen to check and it tuned out to work perfectly!!! when i tried with the new screen it still black and after a while the old screen didn't respond as well the new one either black or with lines .
what can i do ? what to replace etc!
Update (01/19/2017)
this is the screen
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
are you replacing the digitizer or the lcd? did you disconnect the battery prior to replacing?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
this lcd display in pic is shot. you will have to replace it with more care as the lcd panel is extremely fragile
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
the problem is i bought it from the website and it came to me in the pic you see
さんによる
hi Maryam then this has likely to have happened in the post due to the fragility of the LCD crystals in the display. it is not uncommon for us repairers to lift a lcd display working and replace it finding it damaged even with the up most care being used. the replacement will solve your issue thought and isolate the battery prior to replacing the display
さんによる
コメントを追加
回答を追加する
maryam さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 265
