Lines on printed pages
There are lines that print on the left side of the page that comes out. It looks like the lines are coming from the spool that pushes the paper through.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Jamie Teibel , You very well could have ink on the rollers transferring to the paper. For detailed instruction on cleaning the printers rollers click on the links below. Good luck.
I hope this helped you out, if so let me know by pressing the helpful button. Good luck.
http://smallbusiness.chron.com/clean-hp-...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 58
1件のコメント
are the lines vertical or horizontal on the page? It is possible for the feed rollers and paper path rollers to get dirty and leave marks. If you can see dirt on a roller then use alcohol on a cotton swab to clean or use a thin lint free cloth with alcohol to clean. The space is tight and hard to get to the rollers in some models.
DrGlowire さんによる
