メインコンテンツにスキップ
I think my phone is bent
I tripped and my phone was in my hand, since then I have been thinking that the fall bent my phone. I replaced my screen protector and the new one has gotten a decent bubble coming up the side of the phone and at the top. I have put the phone screen down on a counter top and it wobbles a bit. The phone works perfectly fine otherwise. But I was wondering if there is a way to unbend?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Joe Ziemba, May be best to thank your lucky stars phone is working properly and just possibly a little bent. If you try to bend it back something could possibly break. Just my 2 cents. If it really does bother you, I will post a tear down links of your phone which may be useful, as maybe just the battery is damaged/bent and can be replaced. Good luck.
https://www.youtube.com/watch?v=lhAFtP0F...
Nexus 5X Teardown
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thanks for the quick reply, I get that something could break, which is why I posted the question before trying anything. I didn't know if I would be able to easily take everything out of the phone and attempt to bend the frame back...
さんによる
Joe Ziemba, Joe the video link in my answer will show the disassembly along with this link, if you would like to try bending it back.
Nexus 5X Teardown
さんによる
コメントを追加
回答を追加する
Joe Ziemba さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 946
