メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
耳全体を覆うフルサイズのヘッドフォン、通称サーキュマル・ヘッドフォンの修理ガイドとサポートです。
Left ear cup not working on August EP650 when using cable.
I have a pair of August EP650 and they are both wired and Bluetooth. Because of a slight quality increase and no battery life, I like to use a male to male cable but there is no audio coming from the left cup (where you connect the cable). Using Bluetooth, the audio works on both cups and I used multiple compatible cables but it still doesn't work. I took a picture of the port and Ivan see a red and a black wire and a gold bar that is more on one side.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
I realized that when I bend the aux (not the cord, the part of the male to male that goes in the headphones) the audio works in both sides. Also when I don't put the aux in completely, audio works fine on both sides as well. Could the port be broken?
さんによる
I have the opposite problem. On bluetooth, sound is only coming out of one ear but on direct connection, both ears are working fine. Strange?
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi,
The tip connector spring inside the headset socket has either lost tension or the socket has a dry joint or loose connection to the headphones.
If the problem in the socket itself it will have to be replaced as they are irreparable.
You can prove where the problem is by opening the headphones and plugging a stereo audio cable into the headphone socket end only. Then connect an Ohmmeter between the tip of the jack plug at the end of the cable and where the tip connection of the socket appears in the headphones and see if there is a reading on the meter or whether it comes and goes by moving the jack plug. You could also check, if the socket is mounted on a pcb whether it is loose and all its' connections are soldered properly.
Here is an image of the connections used in a conventional headphone jack plug.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Marc Robertson さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 4
過去 30 日: 8
今までの合計 1,578
