メインコンテンツにスキップ
Model 5234us. 1.66GHz Intel Centrino Duo
How to put the Ribbon back rightin the compuyer
I took out the ribbonon my computer hp pavilion dv5000 to put in new one and for got how the ribbon go back in can your help me out here please thank your I took the ribbon out of the computer to put in new ones but for got how to put them back in right can your show me how to put them back inThank your
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
As you do not say which flex ribbon cables you are asking about, here is a link to the service manual for your laptop.
If you scroll to section 3-4 it gives an exploded view of all the parts in the laptop. Once you have identified the particular cable that you are interested in, its' identity should allow you to find where it is connected to in the service manual and from there it should tell you the necessary pre-requisites and then the procedure to remove /replace the cable and the associated component that it is connected to.
http://www.hp.com/ctg/Manual/c00700959.p...
Hopefully this is of some help.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
david michie sr さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 5
今までの合計 108
