メインコンテンツにスキップ
”PS2”として知られた第6台目のビデオコンソールは、Sonyによって2000年3月に日本国内で発売されました。米国では2000年後半に発売されました。モデル番号はSCPH-30000です。このデバイスの修理には一般的なツールが必要ですが、修理は技術が必要です。
186回答 すべてを表示
Fat Ps2 Wont Spin Any Disks
Hello I have a fat ps2 and i took it apart awhile back to clean the console because. I disconnected the power ribbon from under the DVD drive then I just cleaned it up with some compressed air and some cotton swabs without any thing on them.. After I did that i couldn't get the power cable back in under the DVD drive so i disconnected the two ribbon cables from under the DVD drive. After that i plugged the power cable under the DVD drive. but than i released that the ribbon cables were hard to get them back in so i gave up for a few months in the months that the ps2 was taken apart i made sure not to drop it or get dust on it ect. Earlier this week i tried it again and i got the dvd drive plugged in the ribbon cables for under the DVD drive. i went to turn it on everything works but it wont read any disks. what i mean by this is that you can put in any disk ps2 games, ps1 games, movies ect. Not one will spin. I can go into the main ps2 screen were i can go to settings or browser it shows that the DVD drive is there but wont be spin any disks that i put into it. It used to read disks before it apart im pretty sure i didn't break anything because i took apart consoles in the past and they still work. I Googled the problem and look around and i cant find anything thats working i tried cleaning the laser and everything but i dont think its the laser but i could be wrong. all the cables are plugged in. Is there any solutions or should go buy and new spindle ?
I know there is problems like this on the ps2 slim but i cant find any working solutions for the fat ps2. Also the Ps2 has a mod chip in it that was installed by a person years ago.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
i have the same problem too, it is possible that the disc motor is broken (At least thats what i think the problem is)
if it shows no error its most likely the disc motor.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
My Name Is Onion さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 53
今までの合計 3,254
