メインコンテンツにスキップ
GSM iPad 2は16、32、64GBの容量オプションがあり、Dual Core A5プロセッサが搭載されています。モデル番号はA1396。修理作業は複雑で、ヒート(熱)を当ててこじ開ける作業が必須です。
iPad 2 turns off when taken off charger
I have an iPad 2 that is having a strange issue that I cannot figure out at all. If its not on the charger and you try to turn it on it seems like you get a very fast and dim flash from the back light sometimes. However when it is plugged up to the charger and you try to turn it on, it works like normal and shows the battery at 100%. But as soon as you unplug it from the charger cable it shuts off immediately. I thought that it may have been just a defective battery. I replaced the battery but still giving the same issue. After playing around with it the other day I put a little pressure on shielding above the battery connector and it would turn on for along as I held pressure there. I made sure that all the screws were properly secured and i know that the contacts are making contact because it gives a brief flicker of a back-light. What I think it may be is the solder is giving under the shielding. I just want other peoples opinion as to what may be causing this issue.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
It's the Lightning dock
iPad 2 Dock Connector
iPad 2 GSMのドックコネクタの交換
The guide is for GSM, your iPad may not be GSM, find out, or help us to find out which iPad you have
Replace a damaged or corrorded dock connector in an iPad 2 and fix problems with charging and connecting to USB devices.の画像
製品
$19.99
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
shawn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 61
