メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2012年3月16日に発売されたiPad Wi-Fi機能搭載の第3世代モデルです。モデル番号はA1416です。修理には温めて、慎重にこじ開ける作業が必須です。
iPad 3 Restore Error 9
Hello,
One of my customers brought in an iPad 3 (A1416) to me with a battery fault. It was completely dead when it arrived. The battery was replaced, and it powered on fine. Although it was disabled. I tried to restore it but I keep getting the error 9 message.
It seems to happen at the start of the restore process just after it is "extracting software". It resets, the progress bar appears on the ipad, then restarts again then I get the error 9 message in itunes. The progress bar doesn't even make it to 1%.
I have already tried a new charging port connector, multiple different official cables, both Windows and Mac computers, and I still have the same problem. I've used an OEM battery and an OEM charging port. I've even moved the logicboard to another ipad 3 but it's still coming up with the error 9 message.
Any ideas as to whats wrong with it? Any help will be greatly appreciated as I am all out of ideas. Also returning it to Apple is not an option.
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
This is a nand memory fault and hardware related. The only solution is to have a technician with a nand programmer to rewrite the serial number to a new nand memory. It wont restore as the memory is damaged
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Hey tony, curious myself since you seem to have more experience with this issue. Reball is out of question with error 9?
さんによる
Hi Stephen
The error is a serial number conflict with the underlying data stored on the nand. As the device was working prior to restore then it is not pp1v8. In my experience the underlying data is still on the nand but the data signal is not present on restore. For me it is better to rewrite the SN to a new or good nand than to do the job twice. A good programmer will show if there is a fault with the data signal. The fault is not with the balls or pads so no amount of reballing will solve. Most of my customers with nand faults opt to upgrade the memory while the nand is off so it makes sense to upgrade the capacity while undertaking the repair
さんによる
Makes perfect sense. Always great to see an intelligent mind w/ experience on the subject. Thanks again!
さんによる
thank you for the compliment Stephen
さんによる
コメントを追加
回答を追加する
Peter N さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 19
今までの合計 1,934
