メインコンテンツにスキップ
モデル番号A1225 / Early 2009 / 2.66, 2.93もしくは3.06 GHz Core 2 Duoプロセッサ
164回答 すべてを表示
iSight "camera not connected"
Having followed the excellent guide to install dual HDD in my 24" iMac, everything works except when I try to use my internal iSight camera it says: "camera not connected."
It IS listed as a USB device under system profiler.
I have tried:
  • Reset PRAM
  • Disable SIP
Any ideas before I disassemble and check cables etc.?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Thanks for your quick answer. I'll do this next week and report back.
さんによる
OK, so pulled it apart and had a look, couldn't find anything disconnected...
Gave iSight connector a wiggle...
iSight cable disappears behind tape, can anyone tell me where it connects to logic board?
System profile still shows "built-in iSight", with serial number, current available etc. But no apps can activate it...
さんによる
コメントを追加
2件の回答
ベストアンサー
OK, so that was weird... (*See my comments above - pulling it apart and wiggling all the connectors didn't work, nor for that matter did SMC reset)....
However, some weeks later I came back for one last try:
  • I tried to boot in Safe mode... wouldn't boot..showed a circle with a line across it.... then shut itself down.
  • Powered it up again... opened FaceTime... "no camera connected." Darn it.
  • I booted up my old Windows XP installation in VirtualBox, and since iSight was listed in USB devices, I went to "devices>USB>iSight" and tried to attach it to VirtualBox. It wouldn't, Windows acted as if it didn't exist. so shutdown VirtualBox.
Then lo and behold.... opened up Photo Booth and saw my surprised reflection... and a little green light. Then I'm fairly sure I heard/imagined a hallelujah chorus.
Its a bit blurry... might have to pull it apart and give camera a wiggle... or might not risk it....
But I share this in case someone on the internet has the same weird problem that I did.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
No, proceed straight into disassemble the machine and check the cables.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Andrew Vines さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 3
今までの合計 283
