My vacuum is very, very loud
I have replaced the the brush thing and a hose that had a hole in it. But it is still very loud.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@emess117 , Eileen, There could be a few reasons for your vacuum making more noise then usual, Recheck the canister/filters for proper installation and the brush head assy. also for brush/belts installed properly. I posted a couple links below that may help you trouble shoot the noise and then replace/repair the faulty part. If still under warranty contact Dyson last link below, for parts/repair/replacement/refund. Good luck.
http://www.repairmydyson.com/strange-noi...
このアンサーは役に立ちましたか?
It sounds like the HEPA filter inside the ball - if the rubber seal is no longer fitting tightly it allows air to flow through the gap, creating the howling noise. A new seal should fix it (from ptlkmxyz).
過去 24時間: 5
過去 7 日: 45
過去 30 日: 174
今までの合計 37,356
2 件のコメント
After emptying my Hoover yesterday I switched it back on and it sounded so raw and so loud ... I checked the fan belt and the brushes.... Why has it suddenly become so loud i wonder. ....h e l p !
Mo Rick さんによる
Mines doing the same thing but screeching noise here and there, might be just the old age.
Robbie Barron さんによる
