メインコンテンツにスキップ
Repair guides for Sony Cyber-shot HX series cameras.
does this service cost anything
I have a sony dsc-hx-60v camera when I take pictues I then like to view them. When I push the arrow it takes me to a weird looking view that has the picture very small and 4 rectangles on the side with different color flames. I did a factory reset but that did not work
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
The solution is simple: press up on the d-pad when in playback mode. The button that says display on it it will change the way your picture displays. Those little colored flaming things are RGB histograms. They tell you if your photos are to bright or to dark in certain areas. To make them go away and display the photo in the whole screen, just press up. Hope this helps.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I cannot believe the answer was so simple..THANK YOU!! I spent 3 hours last eve trying to get an answer I got a sony technician that could not tell me what to do I was going to pack it up for repairs(his suggestion) THANK YOU again.
さんによる
Glad I could help.
さんによる
コメントを追加
calm check your settings menu for playback. You get there by pressing the Fn button and use the arrows to get to the desired function. Go to playback and check the view mode as well as other settings and see if you can reset that. Yes, it's free on here
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
calm さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 79
