メインコンテンツにスキップ
2006年11月に北米で発売されたWiiは、任天堂初のインターネット接続に直接対応した家庭用ゲーム機で、オンラインゲームと、Wiiショップチャンネルを通じたゲームやメディアアプリケーションのデジタル配信の両方をサポートしている。
288回答 すべてを表示
締切られた回答
3rd Party Nunchuck no longer recognized by Wii?
I bought a third party Wii Nunchuck (I know, big mistake) and it didn't even last for 60 days. I ended up trading it in to Gamestop (if you tell them it is broken, they will still accept it, they just pay a little less) but afterward thought, gee, that was dumb, I should've tried to repair it first - those things are expensive! For others out there experiencing the same problem, does anyone have a repair solution? With my Nunchuck, one day the Wii just stopped recognizing it. I tried resetting the system, the controller, plugging and unplugging numerous times, but no matter what I did the Wii could not see the Nunchuck.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Assuming you actually mean the Nunchuck and not the Wiimote, it could be as simple as bad wiring. The Nunchuck wires into the Wiimote which communicates with the system so there should be no real problem with Nunchuck communicating with the console except with the remote itself. Are you sure that the Wiimote is not to blame? Again, I can only think of bad wiring or bad plug/port.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I know for a fact it was not the Wiimote as I plugged it into another Wiimote and it still wouldn't work. Also, the Wiimote it was originally plugged into is still working fine with the Nunchuck I borrowed to replace it.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,500
