Charger broke off in the charger port! Any idea on how to get it out?
The charger broke off in the charger port and was wondering how I could get it out?
When we went to charge it it broke off
このアンサーは役に立ちましたか?
same bro mine was a jetson rogue
Charger what broke off? The plug? If there was enough force placed to break it off, I'd say the internal receptacle is most likely damaged as well.
One trick I use to get plugs out is to get some Silly Putty. Squish it into the plug, then quickly yank. It might not come completley out, but it should get it out far enough to get some tweesers or needlenose pliers in there.
Other than that, without a pic showing exactly what's going on I can't really give a more detailed answer.
このアンサーは役に立ちましたか?
@kentucyranger I have the same problem but this site doesn’t allow to post a pic
Oh wait I figured it out - pic is below I think the charger broker off in the port
過去 24時間: 0
過去 7 日: 6
過去 30 日: 41
今までの合計 2,136
1件のコメント
@ebane0314 You should post an image so we can see what you are working with
Jetlabb さんによる
