メインコンテンツにスキップ
Miposaur is a robotic dinosaur made by WowWee in 2015 and its model number is OKP0890. This guide will provide resources for and information on repairing a broken Miposaur.
5回答 すべてを表示
Not sure what motor and Encoder MiPosaur uses
Hey guys, has anyone taken apart and reaplace/repair the motors (and if possible, the encoder) on the WowWee MiPosaur toy? I'm doing this because I notice the wheel (on the left) tends to get stuck and sound really squeaky.
I already have taken apart the toy, but I can't seem to find the motor (and encoder if possible) that it uses
Photo of the motor
Photo of the toy
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
Hi, I had a similar problem with a MiPosaur and managed to fix it, at least temporarily. I took the white “gearbox” in your picture apart and saw a gear had migrated on the motor shaft. I pushed it back into position and the robot works much better.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Had same issue as above. Horrible noise and would not drive one wheel properly. Small cog in motor shaft had moved. After pushing it back into place it works well.
さんによる
This part can be knocked loose if it runs into, say, a wall, especially multiple times.
さんによる
コメントを追加
The motor is that metal thing that is conected with a blue wire and another that i can#t see
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
*and a black wire. I dont now from this picture but the motor will probably be one like this: https://www.amazon.de/sourcingmap%C2%AE-...
さんによる
コメントを追加
If the black piece attached to the motor axle is loose, this could be a cause for the problem, as I had this problem, but upon comparing gearboxes with an undamaged part, that is something I noticed.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I created a guide (WowWee MiPosaur Locomotive Problem Repair Guide). You can also find the guide under "WowWee Miposaur".
さんによる
コメントを追加
回答を追加する
NovaViper さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 18
今までの合計 435
