メインコンテンツにスキップ
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
197回答 すべてを表示
Mac G5 will not boot
Dear Sirs
My Power Mac G5 Dual 2.5GHz, M9457LL/A A1047 EMC No. 1969C (June 2004) will not start.
After resetting PMU, it comes chimney sound, the power light comes on - it doesn’t blink, the monitor shows blank bright screen, optical mouse lights. But, computer does not react on keyboard like pressed “c” key, two red lights on the logical board light, one at the power light side and another in the middle of the board, fans would run normal and after few minutes louder and louder.
I’m afraid it’s a big problem. Thank you for your time and assistance.
Sincerely, George
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
Hey folks,
I'm happy to report that I just fixed this same issue.
I actually went deep into the machine, removed the hard drive, verified it using another Mac, made a backup of all the files, and then reinstalled the hard drive only to find out that the same problem still existed. A few hours wasted.
Here's how I fixed it:
  1. Insert the Apple OS X DVD that came with the iMac (mine came with Disk 1 and Disk 2: insert disk 1).
  2. If the iMac is running already then press and hold the power button for 5 to 10 seconds (hard power-down)
  3. Now, with the iMac still powered off, press the C key on the keyboard and power-up to boot from the optical drive
  4. You will see the OS X installation screen... don't worry - there's good news ahead
  5. You want to choose to do an "Archive and Install" which will literally archive your old OS X installation and reinstall OS X from the DVD. Don't worry: you have the option of bringing your user profiles back to life as well.
For various reasons, at the time of writing this, I still haven't logged in to see what is actually in the user profiles but by the looks of this URL it should be OK.
http://support.apple.com/kb/ht1710
Don't forget to vote my post up if it helped you please! ;-)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It sounds like you have the same problem I do with my G5 2.5GHz Quad. I don't have a solution yet, but you might want to follow the thread I started for a freezing G5. I'll ensure the solution is posted there when I have one.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
George Gvozdic さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 4
今までの合計 4,243
