メインコンテンツにスキップ
iPad Mini 2 will only charge if turned off first
After replacing the battery of an iPad Mini 2, I've found that it won't charge unless turned off first and then plugged in.
The steps that I've tried so far are:
  • Tried another battery
  • Factory reset
  • Tried various chargers and cables, both original and knock-offs
Any ideas? I've tried Googling and can't find anyone with a similar issue.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Have you calibrated the new battery? Sometimes, uncalibrated batteries can cause issues with smart devices. Drain battery below 10%, then charge uninterrupted to 100%.
You may also want to check the specs on the replacement battery if you didn't get it from iFixit, as well as ensure that the proper safety certifications are in place to prevent the iPad from becoming a $500 charred smelling paperweight. Check mAH (milliamp hours) and voltage. If you're having trouble with a non-iFixit battery, try the iPad mini Battery from iFixit (and no, I'm not getting paid by iFixit to say that).
I've also encountered scenarios where the device needed a particular sequence after installing or reinstalling a battery:
  1. Turn off the device and unplug the battery
  2. Perform a hard reset without the battery
  3. Plug the battery back in, and perform another hard reset with the battery.
iPad mini Batteryの画像
製品
iPad mini Battery
$29.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dillon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 2,056
