メインコンテンツにスキップ
The Gateway NV52 was released in 2008. It is similar to the MS2274 and NV5207u models.
15回答 すべてを表示
which monitor controller can I use for this laptop
My laptop stopped working, and I'm not interested in fixing it, but I want to use the monitor as a second display for my station, but I need a controller [if I understood correctly], can someone instruct me which controller to get?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
@carrotsy that will depend on your display panel, not your computer. Disassemble your dispaly to the panel and take a look at the label on it. Most common panel for your model is a B156XW04 (there are different version recognized by the V.X number on that label. With that number do a search on either Alibaba.com or ebay.com for a "universal LCD controller board". You should find something like this. Again, always double check your LCD panel. To connect the kit is actually pretty easy. Check this guide for a bit of an idea what you are getting into.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I guess I was wrong again.
さんによる
@pccheese not wrong you just have not build one yet. You are getting there, reps are looking good.
さんによる
コメントを追加
回答を追加する
Salah さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 142
