メインコンテンツにスキップ
The Sennheiser RS 120 is an RF wireless headphone system with open, supra-aural headphones.
52回答 すべてを表示
stopped working no sound no red light
ok - hello and how are all ?
New to this - so question
Sennheiser hdr 120 - had them about 5 years - recently replaced the batteries as thought that was the reason they were not holding the charge. But now new - already charged batteries, still no sound.
Cradle - unplugged, and same with headphones - removed batteries for the 15 min reset, plugged back in and batteries back in - still both no sound - despite tuning and volume up to wait - nothing. No red light on cradle.
I get green light on as soon as i switch plug on for power, just no red light when headphones on cradle.
Been like this for about a week - last time had to update the driver on my pc - and then it worked great until 3 days later, so could be coincidental or not. Just know its getting tedious now and the thought of replacing the whole lot is a tad of a minefield - as too much choice and prices are more now
so all or any help be good
much appreciated
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
Hello I have been having the same issues with mine, the information you gave seem helpful, just where can I realign the wires
(New) looked at the loop piece and one isn’t shiny think that might be the problem, how do I fix it
さんによる
Mine would not charge either, 5 years old or more, no red light, just green. Turned out to be the battery popped out of its cradle a bit!. To access, just turn the fuzzy part of the headphone about a 1/16 turn, gently, the batteries are right there. Easy piezy in my case to fix.
さんによる
コメントを追加
3件の回答
ベストアンサー
eventually sorted - thanks - middle channel a lot better reception. undid the 3 little screws - realigned teh wire, so now batteries sit on the small loops better - retightened - and bingo - i can hear my niece screaming - sorry singing - now. Much appreciated the help
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Hi,
Have you tried selecting a different channel by setting the switch on the bottom of the transmitter and re-tuning the headset?
Also just double checking. Have you verified that you installed the batteries in the correct way and that the battery connection terminals in the headphones are bright and shiny and are exerting enough tension on the batteries to ensure a good connection.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
wow - never realised about the different channel on transmitter - unfortunately this has done nothing - shame. The only thing i do notice on battery terminals - one side is sound - the other the thin wire loop - i had to extend it - as the connection was not on the batteries at all - unfortunately this loop is now quite loose. but now touching the battery
さんによる
Just solved this problem on my system: Take the headphones themselves, turn them over and look closely at the chrome contact area. In my case, I saw hundreds of little hairs (from my head) had collected there, many bridging from one cushion, over the contact area, and to the cushion on the other side. A little bird's nest of my own hair. I removed all of them, re-set the headphones, and "bingo," the red charge light came on. Good Luck. tom@tdgaffney.com
さんによる
The loose battery was my problem too! Thanks
さんによる
コメントを追加
Hi y'all. I have the Sennheiser RS 135 RF headphones and, same as you, I bought it 5 years ago and all of a sudden it just stopped working. Neither green or red lights come on the transmitter and the only sound coming out of the headphones is white noise.
1st Step – Replace the original batteries that came with the system. I figured I didn't know what happens when the batteries die, so maybe this is it. {swapped batteries} Nope. No lights. Next? What's next? Google will know! {found this post and read suggestions. eventually learned how to reset the headphones.} Let's reset!
2nd Step – Disconnect everything, wait 15 minutes, and reconnect power and audio sources. {30 minutes later} {plug in power source. plug in audio source} And….? {crossing fingers} AHA! Yes! The green light is on. {switch on headphones} Yes! Success! {sigh of relief} I can finally watch my shows. {30-45 seconds later} **white noise** {heavy sigh} F@#$. Next…
3rd Step – Change the transmitter channel. The switch was on the middle setting and so I first moved it left. {checking for lights} Nothing. Moved it right. {checking for lights} Aaaand nothing. Sssoooo… Next? Is there a next? I don't know. Back to Google…
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
pudpolo さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 29
過去 30 日: 91
今までの合計 14,106
