Why unable to get any of the 6 light bulbs to work
I brought this for a Christmas gift. none of the 6 light bulbs I brought will come on.
Not familar with this item in particular but there are a few things worth checking;
Is there a fuse in the plug if so is it okay
Is the center pin in the small edison screw lamp holder free of any obstruction
Make sure the centre contact is raised enough to make good electrical contact with the lamp
If you still have an issue please check the connections to the lamp holder and that all connections to the switches and timer are sound. Also check any connections to the lid lock.
Hope this helps
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 15
今までの合計 151
