メインコンテンツにスキップ
1.8 GHz デュアルコア Intel Core i5(Turbo Boost使用時最大2.8 GHz)3MB L3キャッシュ
Help finding refdes for cap
Would somebody be able to help me identify this component? I think I found it on the schematic but I'm not sure which capacitor it is since there are several surrounding the CSD58872Q5D. I didn't highlight it in the picture but hopefully it is obvious (the blown one). Thanks! This is a A1466 2012 MacBook Air btw.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
I think I narrowed it down to C7553 and C7115 (I think, don't have the schematic in front of me) both have the same attributes 62uf, 20%, 11v, poly, case b. So maybe that is enough to find a replacement. Feel free to correct me in case somebody finds this later but that is what I'm going with. Thanks.
さんによる
*C7113 thanks Reece
さんによる
Where can one buy one of these? I have the same issue with mac book air
さんによる
コメントを追加
2件の回答
ベストアンサー
C7513 if it is a 820-3209, and the area above I/O port and bottom right of CPU. Get a board view file for your board to double check
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
@cmp2488 the failed component is reference designator C7513 which is a 62UF 11V 20% Poly capacitor in a Case-B package.
It will help tremendously if you always give the 820-XXXX of the logic board you are working on. Also make it a practice to post an image of the whole board with the location of the failed component marked. That way it is not like looking for a needle in a haystack :-)
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Thanks. My first post so wasn't sure. Will do in the future :-).
さんによる
Do you think this would be a replacement that would work? I wasn't able to find one with the exact specs. http://www.mouser.com/Search/m_ProductDe...
Thanks again!
さんによる
The reason for the details is because it may help someone else down the line. Not everybody is fortunate enough to have the proper schematic/boardview etc. for this model. So your question and the subsequent answers may come in handy to help others. The main reason for the existence of ifixit :-)
That cap might work since it has the same values. It'll be an improved over the one you currently have on your board.
さんによる
Thanks again. I'll see if I can amend my question with those details.
さんによる
@cmp2488 no worries now. Reece identified your board and we're good. Just a consideration for the next time. No big deal really.
さんによる
コメントを追加
回答を追加する
Craig さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 475
