メインコンテンツにスキップ
ユニボディMacBook Pro 13インチ Unibodyディスプレイモデルは2009年〜2012年に製造販売されました。
4630回答 すべてを表示
New iFixit battery capacity dropping after 5 cycles
I purchased a "new" macbook battery to replace the old swollen battery in my 2009 MacBook Pro 13in. The battery I received was rated for 5656mAh. I replaced the battery and used Coconut battery to diagnose the new one, and it said 5519mAh was the full charge capacity after 2 cycles. I figured it takes some time to get adjusted, however, after 5 cycles it has dropped to 4855mAh maximum capacity out of the 5770mAh manufactured capacity. I am worried that I received a defective battery.
Is this the case? Or do i need to deplete the battery and cycle it a certain number of times in order to bring the capacity back up?
Any help would be much appreciated
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント
CAn you look in System information of OSX to see what is shown for battery cycles
さんによる
Edward Coconut battery handles that and much more.
さんによる
Did the SMC and NVRAM resets. Coconut Battery now reads 77.3 % battery capacity at 7 cycles. I believe i received a faulty battery.
さんによる
Tell us what happened to the old battery. That might help determine where the problem is,
さんによる
コメントを追加
2件の回答
ベストアンサー
Do an SMC reset and NVRAM reset. 2009 models should last about 4-6hrs, you will be very lucky to get anything more than this.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
If this is a new battery installation, then calibrate the battery by discharging it to below 10%, then charging it to 100% uninterrupted.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Conor Byrne さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 538
