How do I glue the Bride to the top of the guitar, glue type etc.?
What type of glue do I use to fasten the Bride to the top of the guitar?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@avanti1 ,Duane, A quality wood glue should work for regluing the bridge on your guitar, clean all old glue from old bridge and mounting slot prior to new glue application, then clamp assy. snug(not too tight) 24 hrs.. See links below for more info. on replacement and gluing bridge. Good luck.
この回答は役に立ちましたか?
I think I can do this... one of the UTube videos i watched recommended TItebond II glue, I purchased some and will manufacture a couple "C" clamps and get to it. THANK YOU VERY MUCH!
@avanti1 ,Duane, Thanks for posting back. I really can not see you having an issue and Titebond from what I have heard is a excellent wood glue., good luck with your repair.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 136
