メインコンテンツにスキップ
New Nitendo 3DS XLは2014年10月11日に発売されたNintendo 3DS LLの後継モデルとして、日本国内で発売されました。北米では、2015年2月に発売されました。
380回答 すべてを表示
N3DSXL only turns on with blue light then shuts off.
Hey all. I am repairing a N3DSXL and replaced the bottom screen with a replacement from ebay. Unfortunately, the 3DS won't turn on when I try to boot it up. It turns on with the blue power light and the bottom screen can't really turn on and a slight 'pop' is heard.
Here is the screen I replaced it with:
http://m.ebay.com/itm/Replacement-Lower-...
I did take it apart several times more to check for loose ribbon cables but, no dice. Any ideas what it might be? The screen seems to differ also in that it has one less gray-ish connector on the top. But, that's just what the replacements seem to look like. Everything is connected properly and I didn't forget to connect anything. Could I have connected one of the ribbon cables found underneath the motherboard incorrectly?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
1 件の回答
Hi Janis,
I've answered a very similar problem with a 3DS XL that would shutdown as the user closed the lid. This is the same exact problem as you've indicated here with the "popping" sound. There is a fault in one (or all) of the ribbons in the hinge of the device.
See my 2nd answer here: 3DS XL shuts off sometimes when closing screen, to solve this problem and get your device running again.
Good luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Janis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 30
今までの合計 8,488
