メインコンテンツにスキップ
Can you identify this unmarked antenna box?
I found a mysterious antenna box behind my parents' TV. Completely unmarked except for a logo consisting of three overlapping rounded squares. A Google image search for that logo turned up no matches. The box consists of a circuit board with daughter card and two roughly 8" long antennae. Googling the serial numbers on the circuit boards returned no useful results either. There's also a number 444-1704 on the inside of the case, which also returned no useful results. Anyone here have any clue what the heck this thing is? Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
Thanks! So how does this work? Just amplify any RF signal in the right frequency range? Seems there's no way to program it for a specific wifi network, TV channel, whatever.
さんによる
Not convinced this is a range extender. Check the PCB for any further markings. Looks like it has a 2014 on the board as well as the RxTx sticker leads me to stray away from a range extender. Post a closer picture of the PCB's as well as the back side of the "box"
さんによる
There's nothing to see on the backside, just mounting holes and a Made in Mexico sticker. Doesn't even have the usual FCC labeling and warnings. Hopefully this helps
I posted this same question to another forum. They suggested it was part of a medical system. My dad, before he passed, did have a pacemaker that talked wirelessly to a box that would send data to his clinic. Perhaps this is a range extender for improving this pacemaker-to-box connection. This mystery box has no wired connection to anything but the wall (up-left in pics), neither the pacemaker box nor the cable box nor the cabel modem/router, all of which are nearby
I can't really get a better picture. However, I've labeled the ICs on the PCB
さんによる
コメントを追加
2件の回答
ベストアンサー
Hello. I used Google Lens to find it. Hope that helps.
https://www.geoarm.com/80-922-1-ge-wirel...
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
It's a wireless repeater for an Interlogix (GE) security system (they are now no longer produced)
さんによる
I know this post is a couple years old, but some like mysteries solved. Yeah, why doesn’t a company put a name on it? I was looking for a part and came across this site. Mine came with a weather station to extend the range of the individual instruments. Good luck, Richard
さんによる
コメントを追加
最も参考になった回答
This is a TV signal fetcher/extender. Used in the 1980/90s to improve signal to tv's that didn't use a roof antenna. Also could be a range extender for a signal like wifi.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Dean Lewis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 204
