メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
knocked off components near battery connector
i tried a diy witha solder, not micro solder and knocked off all 6 components next to batt connector. please tell me if i can jumper all and if i can jumper any components conncetors together that wont affect my phone
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
There are four capacitors and two resistors. You can short the two resistors (R61 / R153) as they are 0 Ohm. The capacitors are there for filtering noise off the line so ideally, they should be replaced but your phone will work without them. If ever you see erratic behaviour, then you will want to replace them.
These components are tiny, measuring just 0.5mil X 1mil and they are in close proximity to the battery connector. This is by no means an easy repair unless you have the proper tools and some experience working at this scale. Please don't just assume you can use a standard soldering iron otherwise you risk damaging your logic board even further. There are plenty of videos on youtube that make it look easy but these folks are using multi-thousand dollar micro-soldering workstations under stereoscopic magnification.
If you don't feel comfortable doing this yourself, then look for a repair shop that does micro-soldering repairs. It shouldn't be a very expensive repair.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Thanks for the answer, also can I not connect any components together like the first two, next two and last two together
さんによる
Can the capacitors be jumped and what temp in Celsius should my solder be.
さんによる
I'll repeat the answer: You can short the two resistors (R61 / R153) as they are 0 Ohm. The capacitors are there for filtering noise off the line so ideally, they should be replaced but your phone will work without them.
You don't short capacitors unless you want a non-functional board. What kind of soldering iron do you have?
さんによる
さんによる
I might have peeled of a little of the board and made the lower pads of the last two component that is the resistor and capacitor. What to do?. I'll attach the image soon. I have a lot of Flux there and have to clean it off
さんによる
コメントを追加
回答を追加する
neal kaul さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 165
