メインコンテンツにスキップ
Repair guides and support for the 5th generation Honda Civic, first released in late 1991.
52回答 すべてを表示
constantly overheats the fan works
I have a question i have a 92 honda civic dx that constantly overheats the fan works there is no sign of leakage on the sparkplugs and no sign anywhere else and we replaced the water reservoir, thermostat, and continues to over heat. I have no idea of what else or where else it could be leaking or why it continues to over heat
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@alwayscurious1 my next step would be to change the water pump. A bad pump will just not move the coolant efficiently. Less likely but possible is a blown head gasket. This could let antifreeze leak into the combustion chamber and having it burned with the fuel. Check to see what your exhaust smoke looks like, and check your sparkplug faces to see if it looks a slight rust color. Check to see if you show water in the engine oil on your dipstick.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Sparkplugs where great only oil and water pump was replaced not even a month ago,
さんによる
@alwayscurious1 sorry I missed that waterpump in the question. Anyhow since you already replaced every part of your coolant system, have you had it checked under pressure? Do you lose any coolant? Do you have to add any?
さんによる
コメントを追加
回答を追加する
Amber さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 65
