メインコンテンツにスキップ
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
wont start and insturment cluster says van is in reverse
van was running fine went to place it in park and turned it off when i went to start it again there was nothing noticed then that the indicator for what gear it was in was reverse
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I had it to a shop they told me the neutral switch was located in the transmission housing and rather expensive to fix
さんによる
コメントを追加
2件の回答
ベストアンサー
its probably the safety neutral switch out of adjustment or defective it should be located on steering column down by floor board
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It likely won't let you start the engine unless your in park. It may say that your in reverse because the sensor or switch has broke or possibly moved. I would try shifting through all of the gears (neutral, D2 D3 D if you have them) before taking it to a repair shop.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
bernard gaudet さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 853
