メインコンテンツにスキップ
モデル番号A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5もしくは3.5 GHz Core i7 Processor, ID iMac14,2
Can a 4790 (non-K) CPU replace a 4771 CPU?
Can one replace the 4771 with a 4790 (non-K) in a late 2013 27" iMac?
We're upgrading from an i5 and the 4790 is a more popular processor and therefore cheaper than the 4771 (and more powerful). They both have the same wattage and I've read that as long as that and the physical socket is the same that it should work as Apple doesn't actually have firmware restrictions on processors.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Here are the specs for the CPU's you are talking about:
- i7-4771 Processor (8M Cache, up to 3.90 GHz)
- i7-4790 Processor (8M Cache, up to 4.00 GHz)
さんによる
コメントを追加
2件の回答
ベストアンサー
You choice for CPU is limited to what Apple has used in this series: iMac14,2. You do realize the 4771 is an i7 chip not a i5.
First here's the IFIXIT guide to replace the CPU: iMac Intel 27" EMC 2639 CPU Replacement.
Frankly, the amount of gain here given the risks of damaging your system in my mind doesn't make it worth it.
Many people (including me) have damaged the display just trying to open the system if you've never done one.
Frankly, I would look for a used or newer system that met your needs Vs trying to upgrade the CPU in this series. in the long haul it will be cheaper.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
We do understand it's an i7, hence the upgrade. I was referring to this article: http://www.everymac.com/systems/apple/im... . The TDP from the 4771 and the 4790 (non-K) do match. And the TDP matches the mainboard.
We'd give the computer to an authorized technician who doesn't have a problem with us supplying the parts.
さんによる
Eric - You confused things here: "We're upgrading from an i5 ..." & the 4771 is a i7 chip.
Lets start again, what is your exact system? You've noted it being a Late 2013 27" model is this not correct? And what is your current processor? Also, why are you replacing the CPU?
さんによる
Our current system is a 2012 27" i5-3470 iMac, we are replacing the mainboard with a mainboard from a late 2013 27" model at an authorised technician, but the mainboard comes without a CPU, and looking at CPU models a 4790 is nearly always cheaper than a 4771.
さんによる
OK, I think I'm getting where you're headed here. Boy that was nasty they stripped the CPU on you.
The heat sink is a bit different between these series from what I remember. I'm not sure your 2012 model will work if that was your intension.
You're a bit of a trailblazer here, I don't think anyone has tried using a different series logic boards within the 'Thin Series' iMac's or even tried using a different processor than what Apple had used. Of the two 'thin' Systems I've had to replace the CPU on (burned out) I used what was intended so I can't give you an answer here if the 4790 chip will work.
さんによる
コメントを追加
I just tried i7-4790 on my iMac 2013 27 inch, it wouldn't post, the LED has 1 light, 3 dark. so I know power connection is correct.
but no peep sound, so i don't think it's the RAM, because when i had problem with RAM before, the system would make peep sound, i think it was 3 long and pause (i forgot, it was 2 month ago)
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Imac cuối 2013 chỉ hỗ trợ cpu i7 4770s và 4771s thôi bạn
さんによる
コメントを追加
回答を追加する
Erik Jeny さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 16
今までの合計 1,029
