メインコンテンツにスキップ
The Canon PowerShot G11 is a point-and-shoot digital camera designed to be easy to use for photography enthusiasts.
12回答 すべてを表示
Do you have a guide for replacing the LCD and the LCD cover?
On my Canon PowerShot G11, the LCD is broken and the case that holds the LCD is dented. I need to replace the LCD and the case as a unit. Do you have a guide for doing this? If not, is this something that I can figure out based on your guide for replacing the rear cover?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
@jthomson29 this should work for you:
You may have to do a bit of searching but every now and then parts are available at places like this.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I am pretty sure you could figure it out from the rear cover replacement guide, it looks like it is just two or so more screws then it comes off. The problem is going to be finding a replacement that comes as the whole unit not just the screen.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jim Thomson さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 6
今までの合計 224
