メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1233回答 すべてを表示
Cannot connect to App Store, Cannot Update!
This is driving me insane!
My iPhone 5c seems to be trolling me. For example it believes that it's 7:00am and November 26th. The GPS also just won't connect. It will not allow me to update to the next version. No matter what I do, from hard resets, to wiping the phone and starting over on it. Nothing works.
I cannot even access the AppStore. It says unable to connect. However, when using my other iPhone 5c I can connect to the AppStore. The time works perfectly. Everything is great. So I know there is no issue with Apple App Store. It's just my phone. I should've know better to buy this (extremely cheap) thing from the local shop on the corner.
TLDR: Anyone knows what chips I need to replace to make my iPhone 5c work? I'm guessing this is a motherboard problem and since I have a decent amount of knowledge in soldering I'm pretty sure I can fix it, if I know what chips to replace. If this is not a motherboard problem could it be something more simple like a SIM card issue?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
Have you used iTunes and do a restore or update via that?
さんによる
Yeap. The phone hates me. I haven't a clue as to what could be wrong. I know it was a used phone but that doesn't explain why it's behaving this way. The last thing I ever want to do is throw it away because it works well, minus those two things I mentioned.
When trying to connect and update by using my MacBook it shows a error saying it can't update. I wish this was a simple problem but I have a feeling I will need to go to the nearest apple store. I was trying to avoid that as it has no warranty but oh well. :(
さんによる
コメントを追加
1 件の回答
You should take it to the apple store, it's most likely a logic board issue.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Ugh, I was hoping you wouldn't say that. I'm sadly thinking you are right.
さんによる
コメントを追加
回答を追加する
Crow Rat さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 124
