No Heat No Radio
I turned my van on and the the heat and the radio are not working. I recently had the alternator replaced. The check engine and the break and ABS light also came on and will not shut off. The van is on and moves. Does anyone know what this may be? Is there a work around?
Hi, Take your van to an AutoZone store and get a free scan of the OBDII port. The scan result will let you know what the problem is. Be especially concerned since the brake warning light is on since it usually means that there is something amiss with the brakes!
jayeff さんによる
