change the komplete keyboard in a MacBook Pro 5.1
I have to clean my keyboard because of an "drown in a drink" accidesnt ...
what can I do ?
この質問は役に立ちましたか?
what can I do ?
この質問は役に立ちましたか?
I bought mine from [www.thebookyard.com|The Book Yard UK]. They have 4 variations of the keyboard - US, UK, SWE and INT.
I would say to browse under the original MBP since you're using the 5,1 as I am, look for the keyboard which matches yours. At least thats what I did, and it works perfect.
But the screws, be prepared for 49 mini screws for the keyboard, and about a million others just to get to it.
In order:
(I ran a spudger along the stuck down parts to loosen them up rather than forcefully pull the pieces off)
That should get your keyboard out. Just reverse the order to put it back, and If you really want to get the LED and diffuser panel to stick back then i suppose just use super glue.
Hope it helps.
このアンサーは役に立ちましたか?
if its the ong one in the systemprofiler
these are the las four letters ...
8E98
cheers T/
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,555
