My phone says its on airplane mood but it isnt?
my phone is active but wont let me send messages or make calls it says my airplane mode is on but everytime i check it is not on? help me fix it. cant afford a new phone.
First of all, check your settings then Wireless and Network. It might have a Wi-Fi calling mode turned on, which might cause some problems.
Then try to reboot the phone which helps removing glitches and bugs.
Though this is sometimes tricky depending on your phone, but try taking out your battery for about a minute and put it back in. Make sure the phone is shut down during the process.
このアンサーは役に立ちましたか?
How do I fix my phone?
This happened to my moto G9. After trying a lot of online suggestions still not fixed. I retraced my activity beforehand the phone crashed. Google maps had led me into a cul de sac. Not relevant. I went to settings opened apps then google maps. Cleared cache data and problem solved. Not sure if I rebooted phone. Phones grand now.
press power select restart hold vol down till boot menu comes up select bp toolsto restart i have to do this every restart but works for me
このアンサーは役に立ちましたか?
No answer for me am trying it too, it not working.
Why is mine not working am trying all the method and it not working.
what device are you having the-problem with you enter the recovery menu options do you have the the options listed in my previous answer to this question
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 23,119
i need help fixing my phone.
destinygilbert42 さんによる
How do you reboot the phone and I don’t know how to take the battery out.
deepblondedeb さんによる
My phone is stuck on flight mode and won't let me make phone calls or send text messages even though I reset it switched on and off it still won't let me use it
williamsedwin45 さんによる
Can't use phone in airplane mode it isn't can't afford a new phone only 6 months old
Rosemary Berman さんによる
My ZTE ph is telling me can't make calls because airplane mode is on but it's not has no icon light up saying its on
Dwayne Childers さんによる
1以上のコメントを表示
