Nikon D7000 Autofocus sensor removal
How do you remove the autofocus sensor from the mirror box assembly?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
grantkapteyn, The links below to the Nikon D7000 disassembly/dissection may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
このアンサーは役に立ちましたか?
grantkapteyn my esteemed colleague @lpfaff1 is absolutely right . This answer is just for completion sake, kind off like an addendum. The AF sensor is mounted to the bottom of the "Mirror box. It is connected via a flex and held in place by three screws. The ifixit guide will definitely get you there. Part number for that is 1H998-171
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 4
過去 30 日: 10
今までの合計 849
1件のコメント
why would you want to do this.
apcowgill さんによる
