Pentalobe screws iPhone 6/6s/7 Plus
Will iphone 6 plus pentalobe screws fit iphone 6s plus?
Will iphone 6s plus pentalobe screws fit Iphone 7 plus?
Does the pentlobe screws in the iphone 7 plus has any rubber gasket/seal on them?
Thx
Ishay
Q: Will iphone 6 plus pentalobe screws fit iphone 6s plus? A: No the iPhone 6 plus pentalobe screws only will work with the 6 and the 6 Plus.
Q: Will iphone 6s plus pentalobe screws fit Iphone 7 plus? A: No they will only work with the 6s
Q Does the pentlobe screws in the iphone 7 plus has any rubber gasket/seal on them? A: Im not sure haven't worked on one yet
このアンサーは役に立ちましたか?
As I see now someone already answered a similar question here:
Are the bottom pentalobe screws identical to those of the 6S Plus's?
he said that the iPhone 6s Plus has the same pentalobe screws as the 7 plus..
Can you confirm for sure it won't fit?
What is the difference?
I tried to switch between the 7 plus and 6s plus's pentalobe screws and it seems to fit but I don't want to demage the device..
Anecdotally I can visibly see something black on the top of the shaft under the pentalobe head, whether that is for water resistant protection or for sizing compatibility I am unsure. I can update this comment when another 6S Plus comes to me or repair.
I have a question can I use iPhone 5s bottom screw with iPhone 6?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 9
今までの合計 2,818
