メインコンテンツにスキップ
2013年11月22日に発売されたMicrosoftの第三世代のXbox ゲームコンソールです。
727回答 すべてを表示
Xbox One will not power on Power brick stays orange!
Xbox one will not turn on would not make a noise, now I have changed the the RF board on the front and it now makes a BEEP but no lights come on, the power brick always stays orange, I can use my second Xbox one Power brick and it will do the same thing but go from orange to white to off. Anyone have any ideas what it could be?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Usually in this case it's caused by the southbridge but not always sometimes there is some other random component on the motherboard that is causing it.
I'm sorry I can't be more specific but there is just no way to know for sure without testing it.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Okay how can I test it I have everything except the reballer, I'm a Server technician/engineer I'm entrusted in at least trying to figure it out.
さんによる
Unfortuantely there are no schematics with these...that's the main problem. You can either do your best to check each component that powers the console or you can replace the southbridge and hope that was the problem. Unfortunately there is just no really good way to diagnose this problem.
さんによる
コメントを追加
回答を追加する
michael turner さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 2,338
